I need a little help with a math type problem and hope somebody can help me (brain storm) this problem. My dragster currently uses a 1.80 ratio low gear in the powerglide and a 3.82 rear gear. If the car is on a terror type run it shifts into high gear at 1.5 seconds and that is right at 8000 rpm. Im looking to change the low gear planatery in trans to a 1.69 ( I would like to have a 1.55 to 1.60 but it doesnt look like that ratio is ever going to be made).
The goal here is to stretch out the distance traveled in low gear before the shift. Im thinking that it currently is about 200' out when it shifts. I would like to get to around the 330' mark!! BTW tire rollout is about 108"
Question of the day is , how much further (basically) will the car go with a 1.69 vs the 1.80 low gear still shifting at 8000 rpm???? Mike
