SignUp Now!It's PIN A13...the digital ground terminal.What pin is that?
You can utilize the Switched Ignition Input wire that goes to B19. This it the pink +12V switched wire.Is their a switched 12v I can use on the xfi so all 3 will be connected at the xfi
hmmmm..... I answered this for you alreadydoes ford sensors work with the xfi?
asloan5,
Are you looking for FAST to confirm that the Ford sensor will work interchangeably with the GM sensor? FWIW, I asked the question in an e-mail to FAST guy this morning but have not gotten an answer to that question.
Conrad
Getting ready to pull the trigger and go to E85. Have ordered 120# injectors and 40 micron SS filter element for post pump filter! Anyone know what these fittings are (Mustang photo @ Novi from page 2) that connect to the GM fuel sensor?
Conrad
The Ford sensor is not compatible at this time.asloan5,
Conrad
Flex Fuel Sensor wiring to XFI is as follows:
Flex Fuel sensor Pin A signal goes to Pin B of XFI shaft connector
Flex Fuel sensor Pin B signal foes to 12v switched power supply
Flex Fuel sonsor Pin C sensor ground goes to Pin C of the XFI shaft connector
Most Buick guys are using an adaptor harness, so won't have a "shaft connector". That is why I stated to put the signal pin in A6 on the XFI.
FWIW: I don't know anyone who has tried a Ford sensor on the XFI. The only way I could see it working is if the output is EXACTLY the same as the GM.
