Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
....Unfortunatly its not the guage. I hooked up a cheepo one I used to check the oil pressure on the 455 and it still showed 2 psi at idle!!![]()
I ruled out the pressure relief valve when I pulled the pump cover off so that shouldnt be the problem. Really makes me mad that on a fresh rebuild I have low oil pressure.....
The sweet spot for good oil pressure on the Buick engines lies within the main bearing seals and rod bearing seals. The tolerances must be super tight. Maybe you got the wrong sized bearings, or maybe the crank was overcut, (if at all).
Forget the oil pump, filter and springs. Thats just for tweaking. I know for sure that on the stock V6 3.8 it is 6-lbs at about 1100 rpms. 3-lbs is the minumum before the oil idiot light goes on. Probably not much differant for the bigger block.
