i have a std motor std crank low miles block im running ported heads oversized ferrea valves lunati 32508x i believe its a 210/205 , ported intake, bigger plenum/throttlebody spacer, ported header's i want to run e85, and im running built tranny undecided about installing a brake since its 95% street car, will be at track once in a while but not every weekend,,so for converter im running a vigilante 7 disk lock up 32-3500 stall pn#239028-7 im staying with the 3.42's out back, and some DR's 275-60-15's have body bushings and rear arms and atr bar, i'll be running open downpipe, or a 3 inch str8 back open no muffler, im trying to go as fast as possible, im thinking 25+ psi just don't know which turbo? i have a ta49 laying around almost new, but i really wanted a 6262 billet wheel, i think for my combo the 6262 might be a bit laggy for street use.. i need help...im also thinking about running stock cam, rather than the 210/205 any suggestions about turbo/cam pick with my combo? heard of multiple guys running deep in 10's with stock motor's with perfect tune i know the tune is real important...i will be adding a wideband, on the downpipe...and go from there.
