How does this run look
griffgoody
First time recording on PL at the track. 3rd run at 23# AND CRAPPY 60FT 2.2.
1/4 13.2 108.73 MPH. Alky set at 6. Let me know what looks good. And what looks bad. Tks John
Yes, low batt. voltage. But I'm surprised you have the power of the Powerlogger, and aren't feeding it with a MAP signal, or a Wideband.
looks like the filter is still under the hood .air inlet temperature is to high .Also as said before the battery voltage check all the connections.Looks like you didnt floor it until you were going 45 MPH your TPS shows about 3/4 throttle until then
First time at the track with PL. Still trying to learn. Still have parts that I need added in the future. My Lc-1 wideband, lt1 and translator. Hooking up MAP for boost. I think i'm gonna take it to a Performance Shop next yr and have all this done plus a tune. The car has never been tuned. Plus it has alot of wiring going everywhere under the dash. Need to get all that taken care of. But at least I reached my goal of getting into the 12's this yr by running 12.8. Get some tires and a good tune. Maybe 11 next year. :-)
