Went back and made some more pulls with the 6176 and the 6265 yesterday. Wanted to get both on the same day with the same air. Had very uninteresting results. I took the last 2 pulls (which were the best) from each turbo and got the boost as close as i could on each comparison pull. With 21* advance and the 6176 made 468.61 peak hp and the 6265 made 466.59 peak hp. The peak hp did not occur at peak boost for the 6265. It was at around 26.5psi at its peak hp. The 6176 was at around 28.2psi at its peak hp. The 6265 started to boost creep over 5500rpm and peaked right before i aborted the run. The wastegate hole was untouched and as received from Precision. The 6176 showed the opposite effect and actually started losing boost slowly from about 5200 on, dropping to 25psi at the same spot the 6265 had over 28psi. The 6265 showed about 11 more hp at the same spot on the graphs where it hit peak boost. With 22* advance the 6176 made 475.81 peak and the 6265 made 473.63 peak. Both made peak power at almost the same exact rpm and boost was 27.1 with the 6176 and 26.3 with the 6265. The 6265 showed the same boost creep toward the end of the pull as the lower timing runs and made more power there again. The 6176 .63 Garret combo spooled considerably faster than th 6265 turbo even though the 6176 is a journal bearing and the 6265 is a ball bearing cartridge. The 6176 hit 27psi by 4600 rpm and the 6265 hit 27psi at about 5200rpm. This tells me that the PTC 9.5" i am using needs a slightly different pump to achieve the same spool rate with the 6265. Given these conditions the 6176 would likely out e.t the 6265 if both were launcehed at moderate boost levels of around 8-10psi or less. i did not road test them but the 6176 would likely hit a lot harder on the butt dyno looking at the graphs and comparing boost and rpm. The 6265 would likely out mph the 6176 in all instances based on the boost not falling as rpm climbed with the 6265. If the 6265 were launched and hooked over 10psi it would likely out e.t the 6176 since it would be into the effective boost range much quicker. For all runs the ambient temp was between 70 and 74. Barometric pressure was really good at 30.1-30.2. Charge air temps were almost linear on all tests and dipped to around 8 degrees below ambient on all pulls and slowly creeped up a couple degrees throughout the pulls. I had a considerable amount of tension on the wastegate arm for the 6176 pulls and a lot less for the 6265. If i needed to i could have easily cranked the 6265 over 30psi. The 6176 started hitting a lot of backpressure at 25psi and it was hard to get it to 27psi. I also attempted to test a PT53 but could not get the boost over 22psi due to a poorly sealing wastegate puck surface. Ill have to grind that one flat and re-test.
