New best Holley
yes 28"s and 3.42 boost is only 24lb boost. It is an early 5857 so it an old Turbinetics F57 exhaust wheel.
Also just looked again.. Dropping into and out of closed loop.
You can uncheck any of the traces on the log.
Try to deactivate some and look at only rpm, the closed loop, afr commanded and actual.
I'm wondering if the alky system is being sucked dry and messing with the afr.
Is it using a lot of alky?
Maybe turn the boost down, kill the alky, and see if AFR commanded and actual are close.
You might want to take a look at your fuel table, it is pulling 30% fuel in 1st and 2nd gear. At about 2.2 seconds in the fuel flow jumps around 176lbs/hr when it goes open loop.
