What heads are you running since the r5671a-9 has a different reach than the stock head plugs?
Do you plan on upping the gap, would help your cruise and possibly start up with E85. I don't see how you couldn't fire off a .032 considering us E3 plug runners are .040 and mid 20's psi.
So this is a double pumper Walbro through a -8 with 96lbers correct?
With the 6768 turbo at 24psi, 11:1 AF/R and that crazy rpm I could see 90% IDC creeping up on you. Time for dual DW's or Jay Racing pumps (these are the highest flowing pumps so far).
No one else is scratching there heads at 6900rpm on a 109 stockish block?
Appears as if that build was a good one.![]()
I got data logs that show 7500 rpm during tire spin. Its not too stockish. 109, stock stroke eagle crank, k1 rods, wiseco pistons, aluminum girdle, gn1s. It was out of my old tsm car. Its built well and is taken apart every winter and inspected. Solid roller cam. Its been mid. 9s in my old car.
This car has stock fuel lines right now. This double pumper and these injectors were at 80 DC with a -8 feed at 142mph in the old car.
On the dyno, going from .030 to .022 was 11 HP. .032 never worked in my old car above 6200 rpm with the stock c3i.
I'm not sure what route I'm going with the fuel system. The goal of the car is to run
9s with AC and so simple my wife can drive it. I'm thinking of going dual dw's and a -10 with 160's.
