C16 is rated at 100 octane with no additives. Q16 Zi dont know about!
Where did you get this # from?????
SignUp Now!C16 is rated at 100 octane with no additives. Q16 Zi dont know about!
Fuel lines are cheaper than Injectors, they also can reduce IDC by over 10%, seen it on other high HP E85 vehicles (3/8 to -8 let alone 3/8 to -10). But if you eventually do swap lines, I'd be curious what your setup sees as an IDC reduction for the same AF/R.
Summit Racing SUM-240015B - Summit Racing® Braided Nylon Hose - Overview - SummitRacing.com
That's the material I'd use if I went back in time, Nitrile and not rubber just like how the rubber O-rings aren't so great after time.
Cliff are you dual feeding the rails?
Be honest Kevin... you're adding it so the track doesn't escort you to the exit.![]()
That's exactly it. My favorite local track is strict. My friend's and I hang out on Friday nights at the local track. We are all married and that's our night out lol. What fun is it if i can't play with my toy on my night out?![]()
You guys should come to No Et at milan the next one is this weekend at milan dragray here in mich...No nhra license no roll bar no problem... Its street racing at the track you can hand flag, bet $$$ in the lanes stand behind the cars, and they rip your time slip in half and dont show ur et...Always a good time....I know the feeling. Going to a chicagoland buick club bracket race this sunday at a local track that removed me in my "TSM" car for no NHRA license.... it sux.
now thats what its all about right there! Family fun!
Went to the track again tonight. I'm having a blast with this car now! I leave the trailer at home and drive to the track. Tonight, my wife and our 3 boys got in the car and spent the evening at the track. I had my stock t wheels on the car with worn out 255/60 dr's.
Best I could do was 11.0@127 MPH with a 1.89 60' lol. That pass I came off the foot brake and it bogged down big time. I did about 3 more passes all were 11.0 at 126-127 MPH all with crappy 60's . The car and track did work together good tonight. If I launched too low it bogged, too high and it spun. The 127 was with out tire spin, so that is a pretty good number with the short tire. To add to it, I was going through at 6350 rpm, that should tell you how bad the converter is hurting the car.
Target a/f was 11.4:1
Boost was 22 creeping to 25 at the end of 3rd gear. When I put this turbo on the car, I did not port the wastegate hole because I planned on never running low boost. I think if I port it and can run 25 all the way down the track it will pick up. Also a converter will pick it up. My duty cycle at 25 psi is 90+%. I don't think a 130 MPH pass is out of the question with these 95's and stock lines. That means a low 10 sec pass with a good 60'.
Here is a pic of the boys on the ride home. I got on it hard from 5-65 and looked back and they were all smiles, my wife on the other hand looked pissed lol
