Pics of garage full of parts 3000sqft full !!!!!
ttaowner
NEW ATR HI FLOW CAT $150
NOS T TYPE EMBLEMS $150EACH
NOS HOOD EMBLEMS $45 EACH
NOS GM $100 EACH
NOS GM DOOR ESCUTCHEONS $150 EACH
NOS GM PULL STRAPS $125 PAIR
203 213 9126 LOCATED IN CONNECTICUT
large items i am not equipped to ship but i can bring the to a ups store and you can pay them to wrap and ship the large stuff.
smaller items i can ship and everybody is welcome by to personally inspect/pick up stuff
i have 8 gta front wheels 4 black 4 gold, $150 per wheel
86-87 gn wheels THESE ARE ONLY CORES FOR GETTING WHEELS REDONE $75 EACH
also have a set of non dimpled 2 front 2 rear gta wheels $500
109 block .030 over it had 10,000 miles on it and a headgasket blew and the previous owner discovered a cracked hypertectic piston so it needs a set of pistons but the block looks 100% good /just clean it $300
complete 86-87 intake with everything $500
bare 86-87 intake $200
also have more 86-87 intake parts/pieces,plenums,heater pipe,fuel rail,doghouse,plenum etc.......
84-85 intake bare $50
84-85 fuel rail with harness $50
84-85 turbo to intake adapter $50
84-85 throttlebody complete with sensors $60
i have a bunch more 84-85 ha motor parts just ask 4 engines in pieces
86-87 turbos as cores !!! $75 yes they have shaft play
84-85 turbo car engine harness $100
84-85 downpipe $60
86-87 downpipe $75
86-87 factory catalatic convertors $150 have 2 ( was offered $100 each in scrap last week)
2 dot rods $50 a set
20 bolt front covers $75
14 bolt front cover $75
turbo car balancer $100
complete cam position sensor with cap $100
never cut na v6 cranks $150 guys have made big power with these dont be scared
never cut turbo crank $300
factory 8.5 posi unit $225
8.5 gm gears used 3.08 and 3.23 ratios $90 a set
1 single 28 spline gm 8.5 axel $50
86-87 turbo engine harness came from a running car i parted out last fall $300
complete running 86-87 turbo engine LC2 STILL IN THE CAR HEAR IT RUN complete with harness,downpipe,intercooler,sensors,relays,pulleys,brackets etc..... $2700
8.5 bare housing $500
8.5 complete rear 3.42 with eaton posi and aftermarket axels $1200
87 chrome grille $150
84 85 86 grille $50-150 depending on condition
i have several chrome headlight bezels $25 each chrome is not perfect these are used after all
headlight bezel parking lights $25 each
parking lights in bumper $25 each
chrome front bumpers $75 each
fenders $100 each
radiator support $60
inner wheel wells non turbo $50 each
inner wheel wells TURBO $150 each
trunk lid original paint NO ROT $175
chrome rear bumper $100
aluminum front bumper support $125 saves 30 pounds
aluminum rear bumper support $100 saves 30 pounds
non turbo flat hood $50
turbo hood $300 /have 2
non turbo gas tank $50
TURBO gas tank $100
complete fuel pump hanger /fuel pump assembly $150 i have these for regular dash and digital dash cluster
chrome trim taillights $60 each
black out trim taillights $100 each
quarter panel end caps $20 each
complete quarter panels cut off larger than factory seams $225 per side
trunk floor cut out larger than needed $100
complete frames $350
rear frame rails $150 per side
12:1 steering boxes $75
1 1/4 front sway bar $50
rear sway bar w/ control arms $60
front control arms $25 each
drive shaft for 7.5 rear $50
non posi 7.5 rear$50
driveshaft for 8.5 rear $100
grey dashpad $175
maroon dashpad $175
grey dash gauge surrond $40
blue dash gauge surrond $40
tan dash gauge surrond $40
maroon dash gauge surrond $40
regular gauges $30analog
TURBO gauge cluster $100
digital TURBO gauge cluster WORKING CONDITION $225
column shift steering column w/ key $75
column shift steering column w/ key & tilt $100
floor shift steering column w/key $150
shifter bezel $50
consoles in grey,black/grey gn, tan, also console parts and pieces NO CONSOLE BOTTOMS
4 speed shifter $50
3 speed shifter $50
blue bucket seats out of cutlass $275
pair grand national bucket seats $225 need recovering
back seats upper &lower sold as a set $125 tan.maroon,grey,blue.THESE ARE OFTEN SHOT FROM THE SUN !
gn rear seat upper/lower $200 set
87 regal dash plaque $75
87 regal limited dash plaque $75
86 and older woodgrain dash plaques $40 limited and non limited
84-87 gn dash plaque $150
glove box door $25 blue,grey,tan.maroon
non limited upper door panels $175 pair blue,grey,maroon,tan
limted door panel interior trim/wood grain and greydoor panel chrome strips woodgrain or grey $35-$75 each
lower doorpanels $100 pair maroon,blue,tan,grey
grand national lower door panels $125
grand national lower concert sound door panels $150
grand national black/gret seat belt complete set $150
seat belt complete sets $100 blue,tan,grey,maroon
3rd brake light $25 maroon.tan,blue.grey
rear upper side window panels $25 each side blue,tan,maroon,grey
rear lower side window panels $25 each side blue,tan,maroon,grey
quarter panel side windows chrome $40 each
quarter panel side windows black trim $100 pair
front window black out trim $60 set
back window black out trim $60 set
front window chrome trim $40 set
back window chrome trim $40 set
back window trim between trunk lid non vinyl top $30
T TOP interior trim pieces $40 each tan and maroon
t tops $100 each or $175 pair
t top roof metal flat panels $50 per side
t top center divider $125
t top exterior trim in black or chrome .let me know what you need!
5 piece gn rear spoiler $250
trunklid gn spoiler piece $100
ANY INTERIOR PLASTIC TRIM PIECE maroon,tan,grey,blue JUST ASK !astroroof parts TELL ME WHAT YOU NEED ,motor,glass,pan,etc
aluminum drums $125 pair
ac box $50
TURBO CAR ac box $100
aluminum t t type wheels $100 each or $350 for 4.
i can take pictures if you need them
ttaowner@yahoo.com
203 213 9126
INNER FENDER STRUCTERS
WHEEL WELLS ,TURBO AND NON TURBO ,BOTH SIDES
VACCUM BRAKES,CROSSMEMBERS,3 SPEED AND 4 SPEED, GAS TANKS EFI AND CARBED
HEATER BOXES,C68,TURBO AND NONTURBO
NEED A FENDER? ALL DIFFRENT COLORS LEFTS AND RIGHTS ABOUT 10 OF EACH SIDE
RADIATOR SUPPORTS ARE ALL STEEL $60 EACH
TONS OF WIRING ALL OF THIS HAS NOW BEEN SORTED. DASH HARNESS, ENGINE HARNESS FOR TURBO CARS AND NON TURBO, TAILLIGHT HARNESS FOR TURBO AND NON TURBO CARS
RAD TOP PLATES FOR 86-87 TURBO CARS OR FOR V8 CARS BOTH ARE PICTURED
$25 EACH
t top under glass parts $50 each
t top center piece $125
tote full of t top bags $40 each
$25 each
whole bunch of side windows, black trim,chrome trim, vinal top,non vinal top i have them all
i have way more of this t top trim than pictured these pics were taken before i kinda organized. i have tan,off white 84 sandstone, grey, maroon and blue
alright i think you kinda got the idea i got a ton of stuff so if you need someting call 203 213 9126 or text or pm me or post in this thread, i have way more than posted!!!! i dont have any bumper fillers!!!!
rear panels,upper and lower,t top and hardtop,tan,sandstone,blue,grey,maroon
all kinds of taillights $50-100 each chrome trim or black trim
all kinds of grilles about 20 in all
all kinds of dash bezels and radio bezels, grey trim or woodgrain with diffrent options
all kinds of exhaust systems
kick panels all diffrent colors
steering columns with keys all diffrent colors,tilt.non tilt, column shift,floor shift
this whole upper shelf is all upper and lower door panels.lower doorpanels with and without power locks, grey,maroon,tan,blue,and gn black and grey. also have concert sound lowers for a gn, or in blue or all grey upper doorpanels manual window or power in blue,maroon and tan and sandstone/84gn t type also have limited upper door panels in grey ,tan and blue. i also sell door escutcheons /chrome trim seperate. i have these in grey trim and woodgrain for regular regals and limiteds
i have 3 sets of quarter panels all with original paint
Make me a really "good" deal on two front GTA wheels and I'll give you some praise James. I paid $100 shipped for the last 2 but need 2 more. I can do a little trading with you if you want.:biggrin:
I've got 4, 8.5" westerns with a 7" as a spare as well as a bunch of other crap laying around.:smile:
i need a grey interior piece...Piece that holds the headliner up at the back window. Goes from pass side pillar to driver's pillar. Do you have one??? Thx Scott
i have lots of used stock regal / t type /gn parts for sale pm me your needs
Do you actually answer the PM's, or do interested parties have to call or text you? I sent a PM early yesterday with no response as of tonight.
S.
S.
I was working at my garage all day and night yesterday and didnt get to sleep til 6am this morning!!! Sorry your not the most important person in my life! If these parts were a 911 emergency i figured you would of called or texted like the other people did. Phone number is below feel free to use it !
MY GOD, James!!!!!!!:eek: What a garage full of great stuff!!!1
Would you let me spend the night in there?? And keep the key??:rolleyes:
Never seen so many parts like that in one place in my life!!! I'm so damn impressed!!
So, I'd be GLAD to be your watchdog!!! ARF! ARF!! How's that?;)
Have to ask....any free samples?:D
Bruce '87 Grand National
Tell you what, keep your parts.
S.
Sorry you were up so late but still no answer to my Question James.:confused:
I am interested in the concert sound door panels. Do you have more detailed pics? How clean are they? Thanks!
