I pulled my engine to do head gaskets and then the pistons just to look at the condition of the bearings.. rod bearings look fine. BUT one of the thin rings on the total seal rings looked tweaked, bent, or some thing not quite right. I might have done this removing pistons Bores looked fine, maybe could use a de-glazing.
Might I be able to order just the one bad ring from total seal? If not what are the best rings to run if I decide to change them?
I hate to pull the girdle just to look at the main bearings to see if they are ok..should I anyway. I have new king bearings in hand just in case.
ALL opinions wanted.
Marty
Marty
