Sa-weet man , I use the RJC 325 Mega cooler, this thing is a monster! I'm looking to go that quick and possibly quicker if possible.My rosewood limited went 11.36 on drag radials and pump gas with alky with an all stock long block. TE62 turbo, CAS V4, and 60# injectors
Sent from my Droid using Turbo Buick
Right on man I have most of those sweet parts too but I have the RJC 325 Mega Cooler and RJC power plate with the stock TB and intake and RJC pulleys too here is a pic of the engine and my home made cold air intake setup.Thanks man. The rest of the combo is CAS V4, RJC plate, Alkycontrol, upgraded fuel system, boxed LCA, Hellwig bar (same 60's as airbags), 255/60/15 MT ET Streets, built trans, shorty cold air, WB, scanmaster, 60s, Bailey Extender chip with LT1 MAF/trans, 3" RJC DP, good alternator set to 14.5volts, upgraded grounds, stock: rear, TB, intake, headers/crossover, brakes (vacuum boosted). And other miscellaneous doo-dads that don't affect performance. Not all of this is needed either. My Dutt neck intercooler worked well; I just always wanted a CAS V4 for my next turbo and one came up for sale. I never did 118+ before though and that was the only change so it may have helped. I use marginally less alky, but not much change.
On propane alone (with lower timing (~18*)) 12.1 @ 113mph (and before the TH400 (and brake)) on heavy 17x9.5s w/M&H RaceMaster DRs; the car was pushing 27+psi at the time. Now it is running at 30psi with alky (E85) and a lot more timing (~22-23*).
Mods in the signature.
I've never ran race gas or slicks. Always running meth injection on the street and track. I run mid 11's comfortably with best of 11.2 and 1.5x sixty footers on drag radials and top end of 119mph. I did have to replace the cam after wiping out the stocker. Mlld street cam installed. Stock heads etc. Manage the state of tune and closely watch how the bad boy is performing and these cars are amazing.
Nice man but what happened to the stock cam, how did it get whipped out?
That's a FIRST!!!
Love to hear more about that!!
Heard of diesel trucks usin propane
So car runs on e85 and use propane so u can turn up the boost
JD
JD
It's been really hot here lately and I want to go and tune my car, but in this heat I feel tuning will be nul when the air gets cooler so I'm waiting for cooler temps. What temp,do you tune in prefferably?
If you can make it run well in the heat, then it'll run well in the cold too; you'll just need to add some fuel to compensate for the better air.
Deal with LOT'S of heat hear in florida!!!
alky does help keepin intake temps down!!!
JD
