Eric Stage I
TurboTweak Guy
- May 25, 2001
As long as you can tune the lean spot out using the chip parameters, then you're ok. Otherwise you might have to dig into the VE and AFR tables as Bob mentioned.
Something you mentioned above "I tuned it so it was on the rich side for when I turn the boost up to around 23-25psi." That is not necessary. The fuel will automatically increase as you turn the boost up. The fuel is not "fixed" at one boost level.
