Spark advance in Extender Extreme?
Not Avg 6
My question pertains to the low gear WOT spark adjustment in the Extender Extreme chip. With the default setting for parameter 10 being 8 which is 2 degrees additional advance in first and second. And, being adjustable from zero to four additional degrees. What numbers represent the adjustability from zero to four degrees additional adv. in that parameter?
0 = no additional advance in low gears.
15 = 4 degrees additional advance in low gears.
Bob
Thanks Bob,
Just for clarification and a little better understanding. If 15 is for 4 degrees and default 8 is for 2 degrees addition advance. What numbers would represent 1 and 3 degrees additional?
Originally posted by Not Avg 6
Thanks Bob,
0 zero, zilch, nada
1 .25 degree
2 .5 degree
3 .75 degree
4 1 degree
5 1.25 degrees
6 1.5 degrees
7 1.75 degrees
8 2 degrees
9 2.25 degrees
10 2.5 degrees
11 2.75 degrees
12 3 degrees
13 3.25 degrees
14 3.5 degrees
15 3.75 degrees (ok, it's very close to 4 degrees)
Bob,
Perfect, that's what I wanted to know. Think that might have helped alot of Extender customers.
Thanks again.
Originally posted by TurboBob
0 zero, zilch, nada
1 .25 degree
2 .5 degree
3 .75 degree
4 1 degree
5 1.25 degrees
6 1.5 degrees
7 1.75 degrees
8 2 degrees
9 2.25 degrees
10 2.5 degrees
11 2.75 degrees
12 3 degrees
13 3.25 degrees
14 3.5 degrees
I'm glad you posted that, I didn't understand what 1,2,3 would be ether.
:confused:
