SignUp Now!I did both center two caps and girdle
Which is Stronger? If you where installing a $1000 forged crank which one would you choose to hold it in place? Have we ever established which one was the stronger?Lots of guys building or rebuilding engines. Which bottom end the best?
I was told by a couple shops they would recommend going to a stage block before using a girdle. Not sure why that is, but they view the girdle as a band-aid, and the stock block as a gamble at best beyond a certain HP level. Maybe some shops just have strong opinions, or little or no experience with girdles and would rather not deal with them. The fact is, of all the shops I've spoken to, not one will guarantee that the extra cash spent on caps, girdle, or better block is going to help an engine live under the abuse of racing. So, budget-minded, I went with 4 steel caps on my mild street build, and it's just fine. If I wanted to race I wouldn't use stock anything, I'd go Stage II and set up a separate bank account. But that's just me.![]()
A girdle will add strength to the block and eliminate cap walk. Caps will require a main alignment hone/bore. Usually, a girdle will be slightly more $ to set up then a set of main caps. Using steel caps in conjunction with a girdle is a giant waste of $ IMO. Most big HP 109s have girdles installed. I have used them both and the girdle gets my vote.
So is the consensus to run low tens more than once, a forged crank and either steel caps or girdle are needed. I know tune is paramont when you get to that realm but with a "safe" tune and everything running the way it should what would the life expecptancy be for a forged bottom end with caps or girdle? Once season of racing or several seasons of street driving with a few track runs? Just curious.
