I'm working on a 4.1 stroker motor, and ran into a problem with I discovered after the build, that the piston was 0.145 down in the hole, giving me a really low compression ratio. One of my options is to go with a longer rod 6.500 vs the 6.325. That will bring me up to close to .0045 clearance.
Using some different online calculators, I got a static compression ratio of 9.455, 9.5, 9.7 and 9.64 : 1, and dynamic ratios of 8.1, 8.77 : 1
Jeep Strokers • Dynamic\Static Compression Ratio Calculator
Compression Calculator by ZealAutowerks
United Engine & Machine Co. Incorporated
I'm wondering if these compression ratio's are too high for 94 oct pump gas street setup?
Here are my build specs, with proposed rod change:
4.1 block bored to 4.005
* Deck height of 9.5325
Stroke 3.625
Rod 6.500
Head CC 46
Piston Dish 33.5
Piston compression height 1.225
Head gasket thickness 0.039
Cam intake closing ATDC @0.050 lift 39 (215/220 roller)
Looks like I would have a deck clearance of 0.0045 with this setup
* This is from me measuring the piston in the hole depth of my assembled STD 4.1 short block with a dial indicator. The rotating assembly came from a Stage 1 block that had a deck height of 9.3878 and was 0 decked.
Stroke 3.625
Rod 6.500
Head CC 46
Piston Dish 33.5
