TurboWh1
- Aug 12, 2002
Anybody running one of these balancers? I have the one that can be ran with an internally or externally balanced engine. The issue that I have is there is only about .025 tolerance between the reluctor ring and the timing cover. The stock balancer has about .075. My thust end play is .004 but the engine is fresh. I would think it might end up being .007-.009 after its broke in but I'm wondering if you guys think that .025 is enough tolerance between the reluctor ring and the cover. There seems to be no interferance between the crank sensor and the reluctor ring.
