6gunn
high on gas fumes
- Sep 21, 2003
Attached is the first log with Powerlogger since getting most of the cars issues sorted out. Right off the bat, I can see that it could be leaned out a little. Alky is at 5, so that can probably be turned down. Also, the surging at full boost shows up very well in the log. It's a strange fluctuation which I'm thinking might be caused by a weak wastegate that's unable to keep the boost steady. Just thinking out loud, but I wanted to run this by the experts to get their take on this log.
86 GN
Mods: 60lb injectors, TT 6.1 WB chip, TE44, 3"DP, alky(100% methanol), 2800LU, adjustable FPR (base FP at 43psi vac line off), drag radials.
86 GN
