SignUp Now!I can do it, but there's got to be lots of people closer to you that can do it for you.
OK, I;ll keep that in mind. Is this incorrect?
Here is a pic of my balancer set to TDC +-1 degree. vie is from the bottom up.
This is what I ment....Vacuum value will increase. kPa value will decrease. Pick a type of measurement and stick with it.
Norbs,
I have my engine out for the cam change and can easily take a quick photo showing the same position. FYI - I verified TDC and require any a few degrees correction so it will be close.
Allan G.
OK thanks, any idea why my timing is out 25 degrees? I do not have any ignition module in the crank sensor goes directly to XFI input.
I don't know the typical ignition set-up stratagy when using a distributer but maybe the XFI is picking up the trailing edge and not the leading edge of the slot.
Allanb G.
norbs said:That could be correct, but then all the other people running distributors would all be in trouble like me? I was told by someone at fast, that the fast will fire on the trailing edge like you suggested. How does the factory module do it? It must fire on on the leading edge then?
Holley PN 554-118 is a 3/4-16 hall effect pickup that works with MSD wheels.
Did you use this balancer with your previous setup?
