90% of the distributor guys use the factory crank trigger, there is nothing wrong with using it. It sounds like either the interuptor ring has moved, your keyway is off, or your Safeguard unit is messing things up. I would remove the reluctor (simple way is to just put long bolts in the pulley holes and tighten them down equally), and buy a new billet ring and pres it on at 50 degrees for a better (my opinion) ignition strategy.
