SignUp Now!I don't know how much re-wiring you did when you started having these problems. Have you verified the unused IPU inputs were grounded?
Havent read the whole thread just bits and pieces along the way. One thing I would check is the +- leads to any and all magnetic pickups in this system. If a MSD type mag pickup is wired with the wiring reveresed it will retard the timing!!
Last post you moved the timing to 40 Degrees??? If this has a distributor , did you re-check the phasing of the rotor to the poles of the cap?? Sorry toooooo many beers if Im totally out of line here!!! OUTTA here!!! Mike
No one else has problems, in this config?
Not that I'm aware of. I don't see any record of you purchasing anything from us. Did you make the adaptor harness yourself or purchase it elsewhere?
Just removed all fancy gizmos' that adjust the timing, put 10 back in the reference angle, used a standard timing light, locked the timing in the XFI to 25 degrees and started it up..........timing shows about 0-2 degrees, so its retarded again, just like before, and its backfiring once in a while, shut it down before the plugs get washed out again.
Just a word of note my EST, and BYPASS wires are disconnected and heat shrinked , maybe this is my problem? I am not sure what the caspers adapter does with these wires. Or could this all be caused by the inductive delay being off as CAL was mentioning?
In the Caspers adapter module, you have to swap the green and red wire connectors when switching from coil pack ignition to a distributor.
ON another note my cam sync now shows 24 BTDC instead of 95 does that make sense to you. I installed it at 80 btdc.
Does that mean your using the distributor for cam input?You are 100% correct, but it since I am using a hall effect cam sync and factory crank sensor, moving those wires results in grounding the cam hall input, which I dont want to do, but It could have had something to do with my problem, as I cant find any other reason for my timing to be messed up. ON another note my cam sync now shows 24 BTDC instead of 95 does that make sense to you. I installed it at 80 btdc.
Why??Yes I am using the factory cam sensor mounted inside the distributor, with an adjustable collar.
Well I dont know about you, but when I ran a distributor and used the cam sync inside of it, I had to reverse the wires on the Caspers box as per the instructions.Yes I am using the factory cam sensor mounted inside the distributor, with an adjustable collar. I have physically, seen the cam sensor light go on while moving the crank at 80 BTDC. I have a feeling the cam sync btdc is referencing it self from the time the crank sensor signal is seen..
The cam sync is very unlikely to have any effect. You could probably run it in bank to bank if your tune is close.
