Do you have flow numbers for .100" lift? The low lift flow numbers seem a bit high. An agressive lift for the duration, and 1.71 rocker ratio? You should upgrade to the latest version EAP. It allows you to enter the compressor map of the turbo for better accuracy. Also, 70% efficiency on the turbine housing? This is a T4, right? The flow numbers you're using for your heads don't appear to be realistic. Too much curvature in the graph.
I think I got those head flow numbers originally from Allans heads and subtracted 30%.
Yes its a T4 turbine efficiency is 74% from the garrett site, and Yes I am using 1.71 rockers. I just -re did all the intake flow numbers from the power source book at 40" and I still get Peak HP at 7500 RPM........893 rhp with 20 degrees timing ,not 24, for 35 psi boost.
