Thanks but, this is not the first time I have failed to produce the desired results!
Remember, sometimes it's the journey that's important not the destination
SignUp Now!Thanks but, this is not the first time I have failed to produce the desired results!
Well Allan, lets do some re-thinking, you have heads with bigger valves, bigger turbo, bigger cubic inch, and bigger cam, and you made 923 hp, and with a lighter car you ran a high 8, so based on those factors, it is impossible for me to run a similar time with "smaller components"..........lazaris is correct.
Well, maybe your right, I don;t have "enough" to run those times, so maybe it won;t happen. Maybe I;m over estimating the air flow capabilities of the parts selected.
Its not just that. Your car is very heavy. Whats the total weight with you in the car?
Thats not really saying what the weight is. You need to weigh it.No, idea, but I know it its not light.....
Stage 1 block =39 lbs more
turbo= 45 lbs
intercooler=51 lbs
crank=9 lbs more
4 dp SS is heavy and the 1-7/8 321 stainless headers are heavy..
cast iron stage heads=34 lbs
gear vendors =47 lbs
th400= another 30 lbs over 2004r estimate
dual 3" exh=?
assocatied do-dads=25 lbs..
pushrods=5lbs
battery cables=10 lbs
fuel pump/lines=10 lbs
oil cooler/lines=10 lbs
9 quarts oil=?
Do you have steel bumpers and supports? How about cage? Wheels? Brakes? Trunk firewall?
Could be as high as 3800 w/driver
AG
Thats my point. Now add a 10 point cage that you need to run 8's and a parachute etc etc.
Ok I was just reading he said he wanted to run 8's. I dont know how you do that without testing at the track.Norbs has no safety equipment in the car...because he has no intention of ever going to the track. The car is nothing more than an ongoing experiment.
I just decided to put everything on hold, going to design a direct port water injection system for this........run with the 16 x 16 PWM lookup table in the the fast dash.
Put that on hold its too expensive looking at $1000 ouch, I thought it was cheaper, maybe on the next motor.
Nice stuff though...
http://www.howertonengineering.net/
http://howertonengineering.com/2012/02/hfs-4-n54-schematics/
