.... I;m not going to the dyno until everything is perfect.
Then you'll never be going to the dyno.
SignUp Now!.... I;m not going to the dyno until everything is perfect.
You guys is putting alot of pressure on Norbs![]()
LolThen you'll never be going to the dyno.
Drama queen.............. Enough of the updates already!! Get that thing to the dyno or Beachbum is coming over with the lighter fluid and I will be coming over with the matches.
Update everything is torn apart.............too many exhaust leaks.
Whats your opinion, seem normal to you?Norb, you are not the only one talking about the leak with and Accufab TB. The is a post on the forum where some even called Accufab and they said that normal and no fix...
Clint
Clint
Unsubscribed............
If your that concerned then you can dissassemble the TB and have someone machine an O-ring groove in the ID of the shaft bore. Most likley leak isn't enough volume to amount to anything.
Allan G.
Are you sure you really want to do this.............its just a few exhaust leaks and a TB leak...
So what's it gonna be next week...and the week after that...and the...
This project is very complex to put together, I can;t go to the dyno with leaks! I am very close to getting the bugs out have patience.
