SignUp Now!I ordered another replacement injector and put it in............. I'm putting in stock injectors for now and see if it runs half decent, sold my 95s the fool I am ....What did you do to fix the one cylinder? I bet if you swap in your old injectors and make the appropriate changes you will be fine
I'll post a datalog , it has all those numbers on it...Post up the screen shots of your parameters, ve table, ipw graph.
Is the vacuum reading accurate? Have you checked it against a gauge?
What is your idle rpm target at this point? Maybe too low for now? Looks like 1200? That shouldn't be too low for the cam your using. If anything, it's high. But that's OK until you get this mixture thing straightened out.
Can you identify the trace lines from top to bottom?
It sure couldn't hurt. If you see very low pressures, it could tell you the cam is timed wrong, or just tell you whether or not you have problem cylinders going on. At the very least, let's hope the pressures are all even and normal. That will be one less thing to worry about.Do you think i should attempt to do a cyl leak down before continuing?
