Blown&Injected
- May 31, 2001
This should answer the replies - thanks for all the experiences - it is helpful.
When I did the first rebuild, I had the machine shop do it all including the heads and cam install. It was, I think an ESP Stage 3 - something like a Schneider 205/214 (the numbers should be close - probably not exact). I remember hearing that LT-1 springs are the way to go. The machine shop said we just use LT-1 springs for a setup like my engine but I later thought 70's LT-1 or the newer style??? They are checking it out - the heads and springs.
But yeah, the first cam was broken in on brand new LT-1 Springs. I was thinking about putting my old stock springs on for the first 30 minutes, but I thought if I was good about the first 30 minutes of RPM control I should be good. I rationalized the second cam break in based on the springs now have about 12,000 miles on'em.
Should they be the 70's era or modern era LT-1 springs?
I hear ya! I'm spending right now because of that mistake the first time, but back then I did not have the benefit of Internet to learn of all the problems
Not bad, I was thinking it was a lot more than that - the Comp Cams site kept locking up when I tried to look. Is that for everything - lifters and pushrods? Also, is it nuts to use the stock 300,000 miles 18 year old rocker shafts and arms?
I have read so much about it that it seemed to be accepted . I recall somebody saying something about GM knowing about the problem and something about notations on the prints??? Seems like something is up with that #3 exhaust.
But then science does not try to prove a theory but rather to prove the null hypothesis. Since there are some reports of lots of miles and no failures, it would seem that at least some do not have #3 issues.
Let me know what you want for it and also for the T&D's. I am going to talk to the machine shop sometime this week and will need to make some decisions.
Originally posted by gnx7
Maybe your cam break in procedure has something to do with it?
I break in flat tappet cams with tired stock GN springs as the cam physically hardens in the first 20 minutes of break in time. Thereafter I swap out the springs for my HD LT1 springs or comparable. I was recommended to do this by a friend and other reputable racers have done this also... never had a flat cam.
Originally posted by 86brick
Nope! Just spend the money now and get a hyd. roller cam kit (ductile or Billet) from a vendor like Nick Micale.... The ductile kit is cheaper than the Billet (mainly because you don't have to machine/modify the front cover).... Spend now or spend more later! In the long run you will be happy you got the roller!
Originally posted by EightSecV6
Comp ductile rollers are vey durable, no machining to the nose of the cam is required either, around $400 more than a flat tappet.
Originally posted by Nick Micale
Guess I missed where it was proven?![]()
Originally posted by disco stu
Hey blown& injected, I have a used ATR RP309 G Billet roller I could sell, no springs, but custom, lightweight one piece Smith Bros pushrods. Might make a package deal with 1.5 T&D's.
This cam WILL live in your car, and makes big mid range power. 214 int 210 ex.
