Would it be safe to say, too small of a turbo with a large intercooler would affect performance? Is it possible the switch to a different intercooler exceeded the turbos capacity to function within its rpm range?We already covered this. Real time cooling is minimal. Adding mass is the easiest way to increase cooling but adding to the pass reduces flow. Doubling the pass with no other change cuts flow in half. If pressure drop exceeds 1-2psi then it's too much. It's easy to reduce charge temps by making a more restrictive design. I've got data from two cars that dropped charge temp 40* by switching Intercoolers and didn't pick up any power. One actually slowed down. Unfortunately he didn't have the hot boost pressure. If charge temp is dropping and you aren't picking up power at a rate of about 1% per 10 degrees you are likely introducing a restriction somewhere. Weight should be a consideration also especially with air to air which is hanging off the front of the car.
