I'm working with a high end piston manufacturer to make some pistons for our engines.
If the availability was like a SBC, what would be the specs you're looking for?
Forged and modern ring sets, of course.
Having the come to the deck surface would all for setting quench with head gasket thickness. (even though quench isn't as important in a turbo application). Having it way in the hole like the F-M slugs take that off the table. Being able to set the compression height also allows using different length rods.
Higher static compression than 8:1 adds VE, gives more bottom end, better gas mileage, helps cover up oversized cams, and just sounds meaner
Needless to say I like static to be at least 9:1.
I'm thinking around forged, 9:1-ish with an ave 8445 head, close to 0 deck depending on favorite head gaskets, both press or floating options, and modern thinner rings.
Thoughts?
If I can figure out what to make I believe I can get a pretty good group purchase going on from a 3.805" all the way to 5.500"
bore.
Thoughts?
