SignUp Now!JC Turbo said:A friend was considering switching to a distributor since some of the fast cars have them. I was wondering if you switch to a distributor where would you get the signal and injector timing from since the cam sensor controls this? Could you then use something on the crank since you would no longer need a crank signal with a distributor? I would imagine it might be easier with a DFI of some sort.
norbs said:its up to you but the fastest stock block cars have a distributor.
86brick said:Jezz Roy and Laz are like Rodney Dangerfield they get no respect! :biggrin: Those guys have been 9.30's @146+mph without a dist. Just figured I'd further stir the pot on this topic :wink:
EightSecV6 said:They would go .20's then! I had to borrow a "Cuban cam sensor" in BG from them las tyear.......maybe that is the secret.
I ran 8.20's at 3400# about 7 years ago with the stock ignition but it would go through coil packs rather quickly. Come to think of it, I think Roy and Laz have that engine!
EightSecV6 said:The fastest cars PERIOD! I honestly cant believe it has taken this long for the whole thing to catch on. The dis4 MSD and stock ignition cant hold a candle (literally) to a 7al2 with an MSD crank trigger and MSD distributor.
bruce said:The comparison, isn't fair, IMO.
EightSecV6 said:Not making a comparison, just stating FACTS from experience, I am not an electrical engineer, I build race cars.
A series of 7al2 boxes would cost a small fortune, it would be ugly AND weigh too much IMO.
I think the demand on the stock coils (rpm and load) is what caused the problem in my case.
bruce said:OK, it just looked like you compared the two....
** The dis4 MSD and stock ignition cant hold a candle (literally) to a 7al2 with an MSD crank trigger and MSD distributor.**
EightSecV6 said:That is a fact, is it not? Maybe its an opinion, another opinion of mine is that the DIS4 is a piece of crap as well as the Digital 6.
There is alot more to it than just the FIRE part Bruce, for example, you can accurately change the crank reference as well as the cam sync.
EightSecV6 said:nope
bruce said:Opinions are fine, and are also opinions.
While I've not heard of anything particulary grand about the DIS4/6, your original comment was about a 7, and the stock setup. And, my comment about comparing a stock setup to a 7, still stands, as not being a fair comparison. If you want to compare a dissy Dist setup, then it should be compared to a good DIS CDI, and like you said the 4/6, doesn't fit the bill.
bruce said:Why would you need to change the Crank Reference, on a TR?.
Which distributor allows you to change the cam sync independently of the reference pulse?.
bruce said:You can bypass the EST min engine speed, and set the initial timing to any *degree* as low as the 10d offset of the stock setup, and if you want you can reinstall the stock shutter to 0d if ya want, with the stock set-up.
DR.BOOSTER said:Any chance someone's going to eventually put together a kit for us slower guys to buy?
Ball park figure $$??
Since coil packs and modules are going up in price big time and more and more GN's pull the AC, this sounds promising.
EightSecV6, guesstimate a HP gain by swaping dis's on a mid to high 10 car?
