Another clue, guys. Methanol is very temperature sensitive. Once a certain temperature has been reached in the cylinder, methanol will autoignite all at once. That's why preignition with methanol is so damaging.
The cylinder temps and combustion temps of a straight methanol engine are much lower than that of a gasoline engine. Evidenced by the differing exhaust temps of the two engines.
Temperature control during compression and combustion are key with methanol.
If methanol is pushed to the edge, you don't want anything in that cylinder that might push the charge to autoignition. What is usually the hottest part in a cylinder under high load? The spark plug GROUND ELECTRODE!
Those that are pushing their engine hard and are still using projected nose spark plugs with their long ground electrodes are asking for it. Are begging for it. A glowing ground electrode is all it takes to push methanol over the edge.
I did start out using NGKs that were regular gap with a somewhat cutback ground electrode. NGK is a preferred plug with methanol. If I strayed to a certain lean a/f ratio, I could count on damaging a spark plug. The plug would be removed with the ground electrode melted half the way back. Due to my parts, I was lucky not to have any further damage.
I switched to a different plug. This new one has a fatter and much more extreme cutback of the ground electrode. You would not believe what I've been lucky enough to get away with when the fueling would accidently go too lean. And in a quarter mile run, too. The a/f meter bouncing off a 14.64 reading for a time. Absolutely no damage. Absolutely amazing. I am completely sold on these new plugs I'm using.
Turns out that with the old plugs, that had much shorter ground electrodes than a projected nose plug, the ground electrode was a fuse to a bomb aching to go off.
In my sig is a PB run where the a/f mixture went lean due to a fuel delivery problem, bouncing off 14.64:1 for a full 2 seconds at the end of the pass. You can hear the engine surging in the video. Even the spark plugs came out of it looking fine.
