Phoneguy
Cometic HG stress tester
- Aug 27, 2002
If the intake air temp going over the nozzle is "hot" enough to make the alcohol flash.. then you dont have the issue. Alcohol will flash at 70 DF. If the air going over the nozzle is at least 70 DF.. the alcohol will flash into the air and distribute just like air does.
Example is like brake cleaner hitting a hot rotor.. its gone. If the volume of alcohol is so great that its oversaturating the air.. then we have an issue.
This is why rule of thumb 20-25% of the fueling will get the job done and no issues. Plenty of low 10 sec cars running pump gas and meth no problems. Even some 9 second ones. :wink:
Want to see some XFI logs?
Now.. all this has nothing to do with the damage to the motor Bryan had. He pegged a big turbo due to a faulty boost controller. So all this alky does this/that is hogwash as it pertains to this thread. C16 would not have saved his motor at those boost levels.
If the question is distribution of methanol injection when the fuel displacement/volume starts going past 30-40% displacement.. thats a totally different issue. Then we can start to discuss direct port on that 1200 hp motor.
So if a car with a Buick V6 motor can run in the mid 9's on pump gas and alcohol injection.. that proves the tech works. If it didnt work... then every attempt would be a failure. Its all in the tuning and attention. Dyno's are a tuning aid.. the best advice always comes from those who are methodical about what they're doing and moving in that direction in a slow but sure pace.. I would never set a car on kill on a dyno then expect it to be perfect at the track..
Julio, what happens when temps are below 70* ? My log shows 62* did the meth stay liquid and go to the rear cylinders?
