ek02
- Jan 31, 2008
I bought a new JW flywheel for an internally balanced crank from a board member. I went to bolt it on my spare 4.1 today and one hole was about .060 off. I tried a stock flywheel and it bolted right up, so it was not the crank that was off. A little work with a die grinder got it to fit, but you would think a flywheel that expensive would be drilled correctly. My Chinese Cat flywheel did not have a problem bolting on my other 4.1. Made in the USA ain't what it used to be. I may get this engine in around October to avoid heat stroke so I can check the girdled engine and see how everything is surviving. Our local 1/8th mile track is closed, and will be turned into a rockpit.
