Thats basically the same setup Ive thought about, minus the hilborn injection. Id probably run a holley and a plenum. Just cant run a hilborn on the streets. Of course you loose the hood, but it would let you get rid of the turbo elbow, the intake, and small turbo. The 3 bad things on a CT.
Personally Id get an IC intake, and just flip the doghouse around 180 degrees, and attach the turbo there, but thats me. End up shoving the turbo into the firewall.
And the idea of running the turbo in the stock IC spot is great. Only thought on that, is how does fuel like flowing uphill such a long distance?
Mat, if you want to learn a bit on hilborn theres a recent Hotrod magazine issue that covers the basics of how to set up and how a mechanical FI setup works. Good info in it. October 2010 edition.
In completly other news, looks like I should be able to draw up a CNC lathe program to fit a 87 turbo inducer into a CT cold side in a few months.
