usetaboost
SAY CAR RAMROD!!
- May 4, 2005
The 455 stage 1 pumps are still available. Any way to make one work on a v6? I think guys have said that they're good to mid-low 12s without the return blocked.
SignUp Now!Sorry Matt, I haven't seen them offered in a few years. As far as the engine hitting a wall. You might need some new springs.
Valve springs Matt. What you're describing isn't a tranny issue mostly but the hard hit does sound like the line pressure is to high.So it isn't the trans. Just need to change the rear springs and i will be good?
you can change the valve springs without pulling the heads, i just did a set on a sbc last weekDam, i hope their is a way of changing the valves without pulling the heads..
There are 2 posts in the how to section that will show you how to make the tool and how to use it to change the springs without taking the heads off.Dam, i hope their is a way of changing the valves without pulling the heads..
One line was kinked and the other was leaking. I finally found a set but they were pricy on ebay. It looks like its going to be a pita to change them though.What did you do tho them Matt?
You could always make them out of flexible line Matt. Run them in the frame so there's less heat and exposure on them.One line was kinked and the other was leaking. I finally found a set but they were pricy on ebay. It looks like its going to be a pita to change them though.
