Boost Lights Not Working
HNIC57
...got a problem. I can't get my powerlogger to register proper boost. I have a digital dash with a hobbs switch and a 2 bar map sensor. I also have an aftermarket vdo boost gauge (-30hg to +30psi) that seems to be working properly. I have two problems. One is to get powerlogger to register proper readings. I believe I did the map conversion thing correctly. I tapped the green wire behind the glove box into port #2 of the analog connection block. I also tapped the the gray wire from C437 PIN B, to ECM Port C14 (TPS 5V). On the configuration page of powerlogger I set the MAP Sensor Type to 2 Bar. In monitor mode I am also reading 4.6v to 4.8v. Prior to logging I hit the CTRL B in order to configure. After starting and logging, my boost level at idle fluctuates between -0.1 to 0.1. When excelerating, I get no boost. Anyone with information that can help me out; I would appreciate it......
