Compare data logs?
foxspy
Hey guys,
I went to the track about three weeks ago and did some tuning and making good progress.
I went back last weekend and now I'm alittle confused. The only changes was the outside air temp. The heat index was 108*, where the previous run it was probably 65*.
Here is a picture of each lot showing RPM, Inj Duty Cycle, Actual A/F Ratio, and target A/F Ratio.
Notice on the 2nd shot everything is real jumpy. What would cause this?
Did you change the max logging rate between trips? Appears to be a rate change, you did log one less sensor, don't know if that effected anything or not.
