Coolant additive that creates bubbles???
quicker6
Ihatechangingheadgaskets!
Anyone here ever try using CRC Engine Kool coolant additive?? I dont know if its just me but, I have a can of that mixed into straight water in my car and it seems like after the car has been running for +20 minutes the coolant bubbles up in the reservoir. Im thinking its just the additive because all of the plugs are dry, no milkshakes, and no smoke blowing out the exhaust. Also, on short drives (i.e. 1/4 mile) the coolant doesn't bubble up even though its seen the boost. Im gonna flush it soon but, just thought Id share and see if anyone has had a similar problem.
Thanks,
Derek:cool:
I used that Pro-Blend stuff once and it did the exact same thing. Use Redline water wetter, it is the only way to go, it works great and doesn't foam. Drew
het bro go get some water wetter and some of the new dexron i think its called its the orange coolant. i put those two together and ive sat in traffic downtown honolulu and never broke 168 degrees. i know thats not what you were asking for but i was always taught if something dont look right with coolant than it probably needs attending. i never heard of the stuff you used though. hope it helps.
don.t use dexcool it eats gaskets and heatercores. just look at all of the new gm vehicles eating the intake gaskets, and the 95 and up blazer/jimmy with all the heater cores blowing. mercedes bens has a non corrosive coolant because the entire engine is aluminum and so is the heater cores. then use water wetter.
Originally posted by 65vette396
....... Use Redline water wetter, it is the only way to go, it works great and doesn't foam. Drew
Waterwetter does not foam, but is does NOT contain additives necessary to prevent corrosion in the system. Left in there for a year or so, it will first disolve the solder in the radiator and then the radiator itself.
By the way, no such thing as a "non-corrosive" coolant. It is the additive package that provides protection against that as well as other functions. Like everything in life, it does NOT last forever.
This is not a slam on WW as I used it years ago with these disaterous results.
Yikes, thanks for the replies guys!! I guess I wont be using water wetter. In fact, I think Ill go back to straight water with no additives. At least that way I dont have to worry about stray animals licking up my coolant and falling over;) Is there any good anti-corrosive additive that anyone knows of that is indeed GOOD??
Thanks again guys!!,
Derek:cool:
I’ve had Water Wetter in my GN for years and never had one problem. I flush the system every two years, add WW to fresh green Prestone coolant and run on average 8 to 12 degrees cooler. Idling in 90+ weather and I’ve never broke 170.
As said previously all coolants are corrosive, leaks or breakdowns in the cooling system are from prolong corrosive activity.
this is UNTRUE. I have been using dexcool for 15 years in ALL my cars. Never had ONE coolant related failer. In fact in my everyday car I have 127 k miles and the rad is like new and the heater core has not been changed..and the water pump was like new when I changed it last summer..
THis is myth not fact..
I never used water wetter by itself with only water. They claim it is most effective like that, but as Nick said it does not have the corrosion inhibitor package. I always used it with my usual 50/50 water/anitfreeze mix. I also run a radiator cap with a sacrificial annode, because most all of my cars have aluminum heads/block. The radiator cap is only like $20-$25 and doeas a fantastic job of taking the abuse rather than the engine/cooling components. Hope this helps, Drew
dexcool
my coolant bottle in the park ave. has sludge stuck all over the sides from that damn dexcool...it will not come off, i've used detergents, high pressure water..nothing.....GM is no longer using dexcool
last time I looked GM is still usung dexcool.
All coolants do that stuff buildup on the tank. That means that you are NOT changing it enough..
As was suggested, use RMI-25. I've had many people tell me that they call Water Wetter - Barnical Builder.
I was gonna try that stuff but, Im not so sure which local vendor here carries RMI25. Im gonna flush out my coolant when I change out my t-stat. Anyone ever had a thermostat that got partially stuck open (not fully) that ended up backing the coolant flow into the reservoir some?? My car seems to have that problem and Im pretty sure its the t-stat because even with the fan on HI keeping the coolant at 167 deg. the reservoir still backs up indicating to me that its not heat expansion. Oh well, Ill find out soon.
Thanks again!!,
Derek:cool:
More info...
Derek:cool:
Why would a partially stuck open t'stat cause coolant flow into the overflow?:confused: Partial or full open, system pressure would be the same. My guess is one of 2 options, bad rad cap or head gasket. Remember, when hot, the expanding water is forced into the reservoir, and then pulled back into the rad when cooling.
Would just like to add comments about some of the other posts here. As we have much more severe heat loads on our vehicles here in the desert, we see and experience the extremes in engine cooling. From May to October 100 deg. days are common place, with weeks of 110+ during the "hot" season.:)
For cars that do not visit the freezing temps up north, they do not use antifreeze as it does not cool as well as plain water. For over 10 years, cars that have used RMI with the water, and flush periodically, have cooling systems that stay clean and troublefree.
For the few that need to use antifeeze, it also is treated with RMI changed every season.
If just antifreeze is used, the extreme temps here destroy the additive package it contains before the end of summer, and starts to leave deposits in the system. Have seen very low mileage cars that were stored for years, yet with only antifreeze, the system is very corroded from just sitting. Flushing the cooling system every year is a good routine.
Just because the fluid "looks" fine, does not mean its chemical balance is proper. The comment about sacrifical annode attests to that. The fluid is circulating in a system with dis-similar metals. This is the basic theory behind a battery; hence, you have galvanic corrosion.
There are 2 functions that RMI-25 provides that no other single radiator additive that I have found over the years can do. One is it contains properties to inhibit corrosion and provide the proper PH balance. The other is it cleans the system without a caustic or acidic solution that would be detrimental. [It also contains a surficant like WW to aid in heat transfer for better cooling.]
One final note, a performance car or race car using antifreeze at a drag strip is not only against track rules, but just plain stupid for 2 reasons. If you blow a hose and it gets on your tires, an abrubt visit to the wall can ruin your day. It is also VERY difficult to clean from the track surface.
A blown head gasket can also ruin your day as well as your bearings if the coolant reaches them. A very small amount of antifreeze will immediately trash a bearing. We have had cars driven 30 miles or so with water/RMI in the oil and been able to flush the engine and do the repairs w/o replacing bearings.
Thanks for the info Nick!;) I was thinking that a partially stuck t-stat would cause less flow through the engine thus increasing coolant pressure somewhat in the engine. Maybe Im thinking wrong but, regardless of temperature the overflow tank has been getting back-filled the same amount with the car running (nearly to the vent). :confused: I would think that as temperature goes up, so does pressure so long as the volume is still the same. I dont know.........maybe Im having a Brain Fart and I gotta reset my computer.
Thanks,
Derek:cool:
I highly recommend RMI 25 and distilled water in TR's (that don't get used in the winter) .. Thats what I have in mine and it works great... Mine never runs over 180 in the heat of the summer in traffic with the ac blasting.. I do have a becool and rc dual fans tho:)
