The factory dash used both pnk/blk POS this dash only one. The Analog dash has a 3rd pnk/blk POS at the C2 if you need power to the gauge senders for example.Question for you guys running the Caspers dash connector, on Position 15 [C1-M] on the "Yellow Dot" Board is a feed from the GAGES Fuse POS+ Feed - are you guys using the same feed from Position 1 [C1-A] (Red Dot Board) or are you doing something else….. sorry if this has been mentioned before.
thanks
aaron
I am using the wire on the yllow dot board to run the resistor between that 15M and the brown alt wire to stimulate the circuit so the alternator charges.
