Unplug the factory VSS or the signal you send the ECM will be ignored.On the yellow 2 pulse sender are the 2 wires. One goes to ground and the other goes to VSS. Does the original VSS get unplugged when we remove the factory gauge panel, I'm thinking the obvious yes.
I planned on unplugging the VSS behind the I/P left of the radio area and tapping into the brown wire there. If you have cruise that you want to run, the red wire at the same location needs a signal feed too.Question: What plug are we looking to tap into, and specifically which wire? Pictures would be awesome as I "think" 2 plugs go into the original VSS?
Digital dashes should have a wire up there already at the I/P .
I am not sure I would have to have the dash in front of me. It may be a typo.Question: Does the white wire coming off the 3-wire sender go to plug #2, wire #1 ORANGE ??
I am using the dash mate connector too.Question: Are any of you guys planning to use the Casper's Dash Mate Plug? I will be using it and am in the process of labeling where all the wires go in an excel sheet. I want to share this with all of you but am trying to collect as much info as I can before posting it up. I still have many questions.
