TurboTnZ06
Go on red!
- May 7, 2002
I like 275 my self...
I agree, reflecting back to when I had a daily driver TR's, my low 13 second almost bone stock GN and bone stock T, I ran 275 50 DR's.
SignUp Now!I like 275 my self...
don't think Charlie meant anything by it. I understand his reasoning yet no performance advantage/disadvantage in any way. Charlie are you coming to NC and if so will you be running one of these classes??
.5 Pro tree / Pro ladder
4. Turbochargers up to and including TA/TE 44
So someone will be teching both sides of the turbo? Or just the inlet of a 58mm wheel?
Maybe allow any 58mm turbo with a .63 housing? Either PTE or Garrett housing?
K.
Weights are with driver. So that would put you around the 3700 mark if you are around 190 or soWow been away for awhile and was really surprised with all the new looks to the board....Looks Great!
Seen the weigh tossed around on the 1st page of the thread and just want to chime in that my Gray Regal w/ astro roof weighed 3509 on the scale down there year before last and it's not had any weigh removed. Heck that was with spare tire & jack, laptop & case as well as all the original sound dampner.
Here is my thought, WHY!? now a guy has to buy an expensive new turbo instead of a turbo that tons of people have laying around or can be bought for under 700 new. I don't get why every time someone whats to put a class together they just want to keep making is faster and more expensive so less guys will come in. So please explaine the logic here and why this is a better choice?
Mike
Mike it is a simple recommendation, thats it!! The thread almost ground to a stop so thought I would ask. Shane said he was good and thought the turbo rule as the only holdout to making a class. There is no problem with the 44, just throwing around ideas . If there seems to be no problems with the rules regarding the 44 then Im all for it. Keith also made a suggestion around the same turbo as John had mentioned, I believe that to be the case... We will keep this thread going until after BG is complete. If the basic rules seem to work just fine then I say the 44 will be the victor..
Here is reality, whatever turbo you pick, if you don't have one your going to have to buy one. I got no dog in this fight but it just seems to me that if it cheap and easy more people will do it. This propsed rule is actually better for me in the end I may get to sell some turbos. Have fun boys FYI no one has answered my question as to WHY this is a better choice.
Mike
PROPOSED TURBO RULE CHANGE!!
This turbo is only available in a .63 A/R with multiple compressor covers. Multiple Vendors sell a lot of these turbos and has the same compressor wheel as the 44 and essentially and upgrade from older 44's and would make a good fit for what this class is trying to accomplish...
Turbochargers up to and including 58MM Compressor as measured at the inducer, with E (type) cover (3x2) and up to 62mm Turbine
Thoughts??
Am I assuming correctly that the 58MM limit is the compressor inducer?
