TurboTnZ06
Go on red!
- May 7, 2002
How does the 67mm TE45a 3/2 stand up against the newer turbos? The top end freight train pulling ability of this turbo is what I like.
SignUp Now!I've yet to see the new turbos beat a TE45A in the real word. I'm sure it's happened from reading all the stuff here on TB but it appears to be in the upper boost ranges like way past 20 PSI. Hard to beat a TE45A at high boost.![]()
I have two turbo that would kill a TE45A @ high boost ... but only 1 motor that can handel it![]()
I have a stock 6768 billet turbo on a stock lc2 went 10.90's
I have a built lc2 with a 70GTQ DBB in a TTA ?
What else u wanna know ?
Well i think 10.972 is good for an engine that was hurt to begin with an lifted the head @ the 1k ft mark. This combo would have gone 10.60's easy. The converter needs to be tightend up the car wouldnt build boost at the line then blew through 2nd gear. 6.98 @ 100.43 1/8 and 10.972 @ only 119 because of the lifted head .. Car had alky /race gas and a frontmount. 3,730lb .... Im in the process of putting a small roller cam in the car now with a set of aluminum heads
I went 114mph in the eighth with the t-netics version (66 S) of the TE45a GTQ @26psi and 21-22*timing. Car was over 3600lbs. I was not compressor limited either. Charge air temps were 10-12 over ambient. Backpressure is the limiting factor.
The TE45A is proven beast! I'm sticking with it.
Ive seen TA61's go faster than 10.9's on a stock LC2 so i dont think that its that much of a feat with the 6768.
My 10 sec pass was a bone stock 109 ..2nd pass wit that turbo .But I'm sure someones uncles brother has been faster with less
