Dusty Bradford
- May 24, 2001
I don't see where anything should be changed. Your initial flash is at 2600 rpm which is where you want to cruise down the highway at. It's going from a 1000 rpm idle to 4800 rpm and 12psi in 4.5 seconds with a small ci engine. These motors will not go from an idle to 5000 rpm in 2 seconds without it being a high rpm race motor with a loose converter. Or unless you want to spray it like Donnie.
