Time to go stage II with A/C!
Quit posting...and get back to work.
I've been doing the Stage II conversion for almost a year now, everything does not fit as before, everything takes time. Just to put the oil dipstick in is going to take me almost a day's work., I have to make an AC and alternator support bracket next. I don't recommend anyone do this with A/C in the car, unless you are insane. I still think I am a few weeks away...:(
Thank you for not showing your whole workbench in the last picture.
Video!
Here's a pic of the WG plumbing on the JGS 50 MM gate.........done in -4 teflon.. Notice the 4 port boost solenoid. This will give me more range of boost control without the use of Co2, but in closed loop boost control its not good, way too sensitive, from other cars I tested it on.
The other solenoid is for the Quick spool valve, controlled through the XFI., its either on or depending on the boost level I set. 2nd pic shows QS spool valve.
Air conditioning is of no use when the car sits in the garage all the time, air condition the garage instead, lol.
