SignUp Now!RMI-25 cooling system additive is the bomb! The last cooling system change involved adding a bottle of RMI-25 to the cooling system, and I was pleasantly surprised by the shape of the cooling system during this teardown. I'm sold. It works as advertised.
TA Performance. They have a choice of coated or uncoated. I've used the coated in the past. I feel comfortable with either set. The present set is an uncoated set. They are showing very little wear. Debating whether to change them or not. I'll see what the clearance looks like with the new Stage II cam before I decide. If it's within tolerance, I won't bother changing them out.Where are you geting the cam bearings from, I am looking for a set
So your feeding the distributor gear and idler gear with pressurized oil?The wear to the geardrive is surprisingly low this time around. I have to give credit to the oil for that.
When I first started using the geardrive years ago, I was getting more wear than I'm now seeing. I started out using a different oil than I'm now using and I didn't start out making any special effort to supply a pressurized feed of oil directly to the idler bearing of the geardrive set. It's nice to see the changes I've made along the way help with the durability of the machine.
I'm not running a distributor. I'm running a belt driven drysump oiling system so I don't need to drive an oil pump through the distributor gear, and I don't require a cam sensor signal with the engine management system I'm using. The distributor mounting hole in the timing cover has been eliminated.So your feeding the distributor gear and idler gear with pressurized oil?
