SignUp Now!Ive got an AC delete setup that came from a MC. Ive only seen 2 in my life.
I got an OEM bolt with no rust on it..... talk about rare, got all yall beat
Without a doubt probably one of the rarest parts anywhere is that turbine of urs. That thing will appreciate like gold some day.I have an NOS GNX turbocharger turbine with the correct collar bearing for the ex side. Its the only one ive ever heard of or seen. Much more rare than a NOS GNX turbo assmebly. If you want to keep your GNX original then you need to retain the original turbocharger backing plate since it has the serial # on it. So you are left with two choices: cannibalize an NOS assembly or find a replacement turbine.
I have an NOS GNX turbocharger turbine with the correct collar bearing for the ex side. Its the only one ive ever heard of or seen. Much more rare than a NOS GNX turbo assmebly. If you want to keep your GNX original then you need to retain the original turbocharger backing plate since it has the serial # on it. So you are left with two choices: cannibalize an NOS assembly or find a replacement turbine. Ive had two NOS 9 hole pads and a couple sets of rear fillers amongst other things over the years
Iv'e seen this exact same thing before, as a matter of fact John (GNX 405) has one and he had it at the TB.com event this year still in the same box and with the proper bushing too.. Very rare indeed.I have an NOS GNX turbocharger turbine with the correct collar bearing for the ex side. Its the only one ive ever heard of or seen. Much more rare than a NOS GNX turbo assmebly. If you want to keep your GNX original then you need to retain the original turbocharger backing plate since it has the serial # on it. So you are left with two choices: cannibalize an NOS assembly or find a replacement turbine. Ive had two NOS 9 hole pads and a couple sets of rear fillers amongst other things over the years
NOS black hood molding, rear P/N: 25519949
I bought the molding at an estate sale for $5. The guy had various GN parts. I saw that molding in the wrapper and knew it must go somewhere on a GN.
NOS shifter cable
I found it brand new in the plastic covered with trash in a 87 Monte SS in a junk yard. I got it for $5 too.
I also got the CZF transmission out of that same 87 Monte SS. I paid $140 for it.
Craig
