SignUp Now!Thank you so much!I've got a ported intake for you, just needs a couple bolt holes fixed. Send me a ship address. I understand your situation more than you think. I will send a pm in a few days when I get back home.
Items sent today. 1. Oil pan 2. oil pick up 3. turbo oil return line 4. stock throttle body 5. gaskets for these partsThings Needed: Updated list 6/8/13
Starter
Power steering pump and hoses
Power steering reservoir
AC compressor and hoses
Crank sensor
.005" undersize timing chain
Motor mounts
Turbo
MAF or aftermarket with Translator
Throttle/TV cable mounting bracket
Rod/main bearings. (I'll measure what is needed later
Add to the list .040" pistons (preferably JE stock replacement, as that is what the crank is balanced to,
Torque Converter(am searching for close one)
Thanks so much, I appreciate the kindness.
Jay
These things arrived today! Thank you so much! Very much appreciated!I need shipping address for
-water pump
-fuel filter
-2 oil filters
Thank you so much! That is awesome and a great help!Jay, I see that you'e still in need of Turbo...I just shipped out a TE44 to get freshened up ( I just didn't want to ship you out a questionable turbo) I should have that back in a week or two. Assuming it come back with a fresh rebuild and good shape, it's yours. I will also see at the time what else you would be needing before I pack everything up.
HTH
Prasad
Thanks Vader! Thanks BA!Ok, I got the starter as well.
