WOT fuel and 1st gear fueling ?
ikle
I read a post a while ago and it stated that when you add WOT fuel ( par 1) that you should subtract the same amount of added fuel to 1st gear fueling (par 2) from the default settings (128).
Example: adding 7.0% (137) to WOT fuel ( par 1) you would then subtract 7.0% (119) to 1st gear fueling (par 2) for better spool up..
If this is correct can someone explain to me why this is ?
The only reason I can come up with is after you add fuel to the WOT in all gears that by subtracting the same amount of fuel to 1st gear would bring it down the fuel to the default fuel settings in the chip. I hope this makes sense.
Thanks, Kyle.
