dr_frankenstein
Mad Scientist
- Mar 17, 2008
lol.... i know that feeling.
patience is the key element there.
A.j.
A.j.
SignUp Now!well i have attempted a new type of fuel enrichment and it went really sour on me. so it ruined the bore when i couple of slugs burned up. However.... for the maximum effort guys... PEVR be damned... theres a new sheriff in town.
as for 2.5. it depends on how you plan to push. the stock block will make you 300 hp with a SD crank on 20psi boost. the weak spot is on cylinder number 1 where they clearance the bore for the waterpump. it usually cracks or blows out there. but this really only applys to HD/S10 blocks. as I have yet to try a regular fwd block. I do know the waterpump is different, (which makes me want to try one) in the location on the fwd units so a converted S10 block might be a good try.
A.j.
i hope some one finds a way to make a pevr.
I'm trying Matt but please be patient with me. I've been super busy trying to get the car up and running as well as working on some others for customers lately.
well well well.... another day...
A.j.
yup... its nice out here... 65 and climbing, and sunny, I may pull out the ol hooptie today...
anymore trashed blocks?
Already got a hobbs switch. Opens at 3 inches of vacuume. I got it at surplus center cheep and its normally expensive. Like $80 or something. Got it for $15. I couldnt find a switch labeled on NAPA's websight, but the guy that works there is smart enough to find it.
I need a switch that opens up at 7 PSI to trigger my Alky too.
I did get a vacuume switch through mcmaster carr but it was an industrial one and the holes inside were REALLY small. Wouldnt have responded to pressure differences fast enough.
Only bad thing about my hobbs switch is that I cant adjust it. It is preset for 3 inches but there isnt any screw or anything that I can see where to adjust. Would have been kinda nice if I could have just got 2 of the same switch. One for PEVR, one for Alky.
https://www.surpluscenter.com/item.asp?item=11-2344&catname=electric
Mcmaster carr lists a few switches like I have, but they are like $100
One of these switches was what I wanted to use for my alky but $100 is rediulous, considering I got the same thing for $8.
McMaster-Carr
ITS>>>>>>>>>>>>> ANOTHER monday.........
yay.
A.j.
