WarWagon
Caustic Cacophony
- Mar 10, 2007
I thought all of "those" type of mail trucks were all based off of the Ford Ranger.
SignUp Now!Looks interesting to say the least.
which video is this?
Warwagon is referring to the video I posted of the 87/88 Cutlass Ciera W45 (87 GT or International for 88) 2 door with the L67 Series 2 engine turbocharged (no supercharger) making a 12.83 second run, with a 2.1 60 ft according to the owner of the car (turboL67 on youtube comments); last dyno run he made, the dyno recorded around 450-505 HP at the wheels; and he stated that he wants to reduce the 60' time I'm not sure how he's gonna do so; but he's inspired me to try reach 12-14 seconds with carbed turbo engine in an older Cieramight be for naught, unless i go for newer blocks and distributorless ignition system
oh yeah.
local auto stealership has an 80s Regal 2 door Limited with the half vinyl roof (landau?) and a CRAPPY rattlecan paintjob; needs new bumper up front, clearly fillers need replacing as well; has a 5.0L (307 right?) 2bbl carb engine in there...they're asking $895, but i'd offer $500 if you guys think it'd be OK for a swap candidate?
can you post the link to the thread?I seem to remember a general rule being that for FWD cars needing more power to get to the same times as a RWD car due to the whole weight transfer thing? I mean; I distinctly remember several FWD cars only getting up to 13s or less even with lots of mods to their L67s or v8 swapped into the system; most are also automatics with 4 speeds and computer shifting; not sure what usually required of the autos to stand up to the power, or if its the whole power transfer thing';
i just found the thread where he's talking about dyno time...ok looks like I was a little off; 413 wheel horsepower; but with 20% loss, it equated out to 516hp to 560hp(30% loss) and his sig said 450+ hp. whoops. here's his cam specs and turbo specs; not sure of the compression ratio but think its stock L67;
212°, .520" lift and 113° lobe separation, 60-1 turbo, close to a T61; a 60mm turbo, not sure of hotside or A/R ratio though. he says he hasn't gotten a 120 trap speed yet....so what would that mean? I remember Bison saying dyno's crap, need trap/et to figure out hp? car is around 3200 pounds, maybe a little more, not sure since the L67 and turbo stuff adds weight compared to the stock engine it had.
