CamoDeafie
- Jan 7, 2010
I dont have time to go down to the shop to work on the car. Remember IM NOT a Mechanic, .
we know. when it takes a long time for you to get around doing the compression check, we know you are not a mechanic.
AJ; ive a sketch, the idea is really ODD looking...imagine if you can, a mid engined pod with INDY open mouth nose and instead of a cockpit, theres this pro street/NHRA scoop thing, and it tapers to a point in the back where the muffler goes out....and then on each side, is a bubbly pod containing the seat and instruments for driver and AC system on passenger side, the bubble pod tapers to cover the rear wheel, and the end contains the tail lights and brake lights; there are mirrors for rear view, the canopies are blown acrylic, and you have pretty much full view around the car from it but also isolated from passenger; this would put most of the mass in the middle, and if done like an aircraft (fully monocoque) it should be super lightweight...not sure how to deal with the impacts and such tho
